Date/Time: Sat, 11 Jan 2025 19:43:39 +0000
Sierra Charts Demo
View Count: 1185
[2017-01-09 18:28:57] |
User835748 - Posts: 1 |
Hi, I need CQG data enabled for my trial of Sierra Charts. |
[2017-01-09 19:22:40] |
We see your Sierra Chart account is a paid account. Therefore, you can use CQG at this time . Follow through the instructions here: http://www.sierrachart.com/index.php?page=doc/CQGTrading.php#SetupInstructions If there are connection problem to CQG, you will need to contact your broker about that. If you need further help, let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-09 19:22:58
