Date/Time: Sat, 11 Jan 2025 20:01:04 +0000
Market depth coloring
View Count: 679
[2017-01-09 15:17:54]
User99934 - Posts: 227
The bid coloring on the attached chart shows the current bid 1371 as lightest color for historical bids which were less. The historical bids on that row should be a darker.
Date Time Of Last Edit: 2017-01-09 19:10:04
imagemarket depth.JPG / V - Attached On 2017-01-09 15:09:41 UTC - Size: 63.83 KB - 238 views
[2017-01-09 19:09:24]
The problem is the numbers are getting cut off and you are not seeing the real values.
Increase the chart bar spacing:
http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#ChangingBarSpacing
Also the proper method to provide a chart image is documented here:
Date Time Of Last Edit: 2017-01-09 19:10:33
