Date/Time: Sat, 11 Jan 2025 19:44:11 +0000
Spreadsheet for System Trading saved values of formerly used studies
View Count: 721
[2017-01-09 15:05:08] |
stevenpaul - Posts: 9 |
Hello, I notice that when I open the study, spreadsheet for system trading, I see values from previously used studies. Such studies are no longer on the current chart, yet reference is made to them in fields of the current spreadsheet. For instance, I once used Bollinger Bands and RSI but am now only using the Bollinger %B, yet I see values for the Bollinger Bands and RSI on the spreadsheet. Even if beginning with a clean chart, old studies are still referred to in the spreadsheet. Perhaps I saved the the spreadsheet and that is why values from old studies are still populate the sheet fields. In any case, what can I do to eradicate old study references that are no longer relevant to the current system? Thank you! |
[2017-01-09 18:47:16] |
Just simply delete the data by highlighting the columns and pressing Delete. Or setting the Spreadsheet Study to use a different Spreadsheet through the Spreadsheet Name setting in the Study Settings window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
