Date/Time: Sat, 11 Jan 2025 20:04:22 +0000
CQG/AMP T&S
View Count: 743
[2017-01-09 10:08:25] |
User297539 - Posts: 55 |
Hello SC I have a problem in the FDAX. Already all the time only individual contracts in run and the price as (11537,3 or 11536,8) may not be in the DAX. How do I change that? |
09-01-2017 10-53-28.jpg / V - Attached On 2017-01-09 10:07:57 UTC - Size: 345 KB - 275 views |
[2017-01-09 10:40:41] |
We are not understanding this. So you are saying there are trades at prices received from CQG which did not actually occur? How are you coming to this conclusion. This would be highly unlikely. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-09 10:40:54
[2017-01-09 10:47:13] |
See. The Dax was 0.5 points scale (11550; 11550,5) and in the T & S (11550,3; 11550,8), I can't be in the Dax. And I have no two-digit contracts in the T & S, all single. And I've already amounting to 120000 contracts.
[2017-01-09 11:36:58] |
I think the problem is solved. In the symbol global settings a chopping (Server Version) Only the question of how that happened |
09-01-2017 12-31-13.jpg / V - Attached On 2017-01-09 11:34:50 UTC - Size: 162.36 KB - 255 views |
[2017-01-09 20:05:45] |
The Record Market Depth Data setting is completely unrelated. We had a look at the CQG data for that symbol and we do not see the values you are seeing. Not sure why that is the case. Would seem as though they must be coming from CQG in this particular case. One thing to try is to close the chart the Time and Sales window is for and open a new one in case there is some unknown chart setting causing the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-09 20:06:52
