Date/Time: Sun, 08 Sep 2024 01:42:36 +0000
Is there a HSI indice?
View Count: 784
[2017-01-09 02:50:19] |
bbrunner - Posts: 14 |
Hello there, is there a HSI (Hang Seng Index) real time index I could load it to the chart or put it in my quoteboard? Many thanks Shelton |
[2017-01-09 04:49:32] |
Do you mean the cash index and not the futures?
[2017-01-09 05:51:35] |
Yes the cash index and not futures~
[2017-01-09 06:33:25] |
We need to check on this.
