Date/Time: Sat, 11 Jan 2025 20:02:29 +0000
DOM template copy from X.cht to Y.cht
View Count: 1327
[2017-01-08 18:06:46] |
User608062 - Posts: 5 |
I have a DOM designed in one chartbook.cht. Instead of replicating one column and settings in another chartbook is there any way I can just save as a template or copy to another chartbook ? how can I import only that DOM template to another chartbook? Thanks in advance. |
[2017-01-08 20:40:20] |
Refer to this page for instructions: https://www.sierrachart.com/index.php?page=doc/helpdetails20.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-09 00:34:47] |
Figured out. Working .
