Date/Time: Sun, 08 Sep 2024 01:48:34 +0000
question about custom bars
View Count: 699
[2017-01-08 05:53:09] |
User103949 - Posts: 78 |
Hi, I am new to sierra chart platform. I have been learning ASCIL and trying to create some custom bars. Because my own way to create bar requires each tick data along with predefined rules(not fixed number of ticks for each bar). I found the only way to achieve that so far is to set the chart to display 1 number of traders per bar and then code based on that to create custom study. Below are my questions. 1. Do i have to rely on existing chart to create custom charts? (I noticed the examples provided were all using some existing bars/charts to create different type of bars)? 2. If answer is no to question 1, how do i access to each tick data in order to create my own bars? Thanks, |
[2017-01-08 06:45:09] |
1. Yes. Sometime this year though we do plan to implement the capability where this is not a requirement. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-08 19:48:30] |
Thank you. That function will be very hrlpful. How do I know when the new functionality is ready?
[2017-01-09 18:18:54] |
We would not really expect to have this done for many months from now. There will probably be a general announcement about it on the What is New page: http://www.sierrachart.com/index.php?page=doc/Whats_New.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
