Date/Time: Sat, 11 Jan 2025 19:50:13 +0000
horizontal grid lines do not work
View Count: 2353
[2017-01-07 22:50:57] |
johnz2016 - Posts: 10 |
my step is chart -> horizontal grid, then choose either all regions or a specific region. But I do not see the grid is drawn. Anything that I am missing?
[2017-01-08 01:44:03] |
Refer to the section here for more information: Chart Menu: Horizontal Grid (Chart menu) Maybe the grid color is the same as the background color. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-08 01:44:14
[2017-01-08 04:37:08] |
you are right. The cause is that grid color is the same as the background color. Thanks!
