Date/Time: Fri, 18 Oct 2024 05:53:24 +0000
Forex bid ask spread displayed on a chart
View Count: 1377
[2017-01-07 09:51:10] |
EuropeanTrader - Posts: 290 |
Hi, is there a way I can display an FX bid ask spread on a chart as a number? Thanks! |
[2017-01-09 06:07:30] |
ElmStreetTrader - Posts: 48 |
Yes there is. It can be done by using the following three studies, or two if you only need it on the header, see picture: 1:Bid & Ask Prices 2:Study Subgraph Difference 3:Text Display For Study From Chart |
Spread.PNG / V - Attached On 2017-01-09 06:06:52 UTC - Size: 72.19 KB - 282 views |
[2017-01-09 18:25:20] |
This can be done with the Display DOM Spread option: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#DisplayDOMSpread Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-09 18:25:56
