Date/Time: Sat, 11 Jan 2025 19:49:44 +0000
please explain why the tpo alternating color
View Count: 1161
[2017-01-07 06:50:28] |
whats1thingnow - Posts: 407 |
i got the instructions to alternat colors for the Day and Evening from here: http://www.sierrachart.com/index.php?page=doc/TPOVolProfileCharts.html#DayEveningSeparateProfiles Set the TPO Letter/Block Colors Input to Use Letter/Block Colors 1-18 for Periods .
Set the Letter/ Block Color 1 Input to the color you want to use for the Day session TPO Profile. Set the Letter/ Block Color 2 Input to the color you want to use for the Evening session TPO Profile. Repeat the prior two steps to set colors 3 through 18 in a similar way. You should use the same two colors. my question is, shouldn't letter/color block 1-9 be evening, then 10-18 be rth? the instructions here are saying 1,3,5,7,etc are evening 2,4,6,8,etc are day time? why is that? |
[2017-01-07 07:10:37] |
What is the purpose of the question? This will not change.
[2017-01-07 08:16:21] |
purpose is so i know how i can change the colors for my letters...
[2017-01-07 08:20:36] |
i want the rth to be coloured in different shades of green/yellow then the evening to be coloured in different shades of red/blue |
[2017-01-09 20:28:48] |
The supported coloring methods are controlled with this study Input: http://www.sierrachart.com/index.php?page=doc/TPOVolProfileCharts.html#TPOLetterBlockColors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
