Date/Time: Fri, 02 Oct 2026 18:02:58 +0000
cqg dropping like crazy ?
View Count: 1149
| [2017-01-06 19:28:44] |
| zippyzip - Posts: 310 |
my broker telling me there is no issues , and i am not losing any internet , why is cqg dropping on sierra so much ? thanks for any solutions
Attachment Deleted. Private File |
| [2017-01-06 20:27:34] |
We do not know the definitive answer to this. That is not possible for us to know. Consider using CTS instead: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-01-08 04:08:23] |
| User93757 - Posts: 61 |
I'm having the same issues with CQG/AMP. I'm not saying sierra charting is the issue.
Date Time Of Last Edit: 2017-01-08 04:10:45
| [2017-01-09 01:28:04] |
yea im not saying that either , but i have cqg trader up and i have no issues or missing data , sierra throws lines of messages on log and restarts all charts , just seems strange - so i was wondering if there was something to that .
| [2017-01-09 02:23:43] |
There either is a connectivity problem between your computer and the CQG Web API server or the CQG FIX server. Or a problem on one of those servers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-09 02:24:00
