Date/Time: Sat, 11 Jan 2025 20:09:17 +0000
Alert Sound
View Count: 750
[2017-01-06 18:23:54] |
ripsdips - Posts: 143 |
Ive created an ALERT that shows up on ALERT Manager but It wont make a sound when the condition is met. What do I need to do so that occurs?
[2017-01-06 18:27:57] |
Refer to: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlertSoundSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
