Date/Time: Sat, 11 Jan 2025 19:59:25 +0000
Trade Management by Study for Entries
View Count: 892
[2017-01-06 18:07:08] |
User787778 - Posts: 142 |
Would you please consider creating a "Trade Management by Study" for entries, with the options of a Market Order and a Market if Touched Order. Thanks
[2017-01-06 18:26:13] |
This can be done by using the Spreadsheet System for Trading study: https://www.sierrachart.com/index.php?page=doc/SystemsAlerts.php It can submit an order based upon the conditions that you define through formulas. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-06 18:35:22] |
I currently use Spreadsheets, but would like to be able to change the entry strategy without having to adjust the Spreadsheet. With the use of multiple "Trade Management by Study" studies (which reference to spreadsheet columns), multiple "Custom Study Buttons" (to select the specified Trade Management by Study) and a Spreadsheet, I am able to change the Stop Loss Strategy from my chart. I would like to do the same for entries. |
[2017-01-06 18:45:54] |
Please contact an outside developer to do what you require. We are not able to provide further help with this.
