Date/Time: Sun, 12 Jan 2025 01:04:37 +0000
Pivot Points - Daily -- Use Day Session Only
View Count: 1119
[2017-01-06 13:02:03]
User93757 - Posts: 61
Please check Pivot Points Daily Study - (Use Day Session Only) input value. I do not think it is working correctly, unless i have misunderstood or have a wrong setting.
I am using Two session times, regular and evening. When i extend the session by 'Use Evening Session', my Daily Pivot does not change. The Highs and lows are different when I include the evening session. Please see settings pic attached. Ty,
imagePivot_Study.png / V - Attached On 2017-01-06 12:26:22 UTC - Size: 101.28 KB - 340 views
[2017-01-06 18:32:09]
Here is the documentation for the Pivot Points study:
Pivot Points
Precisely explain based upon the chart data, the Study Settings, the formula being used and the Session Times, a specific example of where there is a problem and why.
And provide a chart image showing the evening session data and another chart image not showing the evening session data. We need a 100 percent clear explanation.
Here are the instructions to provide a chart image:
We did a test and we do not observe a problem.
Date Time Of Last Edit: 2017-01-06 18:35:11
[2017-01-19 09:36:26]
Hi, I was not able to replicate it again.. Perhaps, i should shut down sierra and restart next time before posting. Thanks for your attention to the matter.
