Date/Time: Sat, 11 Jan 2025 20:03:32 +0000
CBOTM CORN MINI not working below daily price
View Count: 657
[2017-01-06 06:52:49] |
User693407 - Posts: 1 |
Hi there, quote XNH17 (Corn mini) has updated to today's date for Weekly and Daily but the 4H, 1H etc are all stuck on the 31/12/16. Wheat, Soya etc are all ok, but I can't get Corn to work. Any ideas? Thanks Nick
[2017-01-06 07:28:59] |
This is now corrected. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Symbol Settings Once that is done go to the chart and select Edit >>Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
