Date/Time: Sat, 11 Jan 2025 19:45:24 +0000
[User Discussion] - zig zag profile
View Count: 2479
[2017-01-06 00:13:05] |
User771416 - Posts: 47 |
Is it possible (and if so, how) to plot a histogram of the zig zag study SG4 (length of the line)?
[2017-01-06 04:53:30] |
Sawtooth - Posts: 4148 |
You can do it with the Spreadsheet Study study. In the Zigzag study settings, set the 'Additional Output For Spreadsheets' to Yes. Add the Spreadsheet Study study and give it a name in the Spreadsheet Name field. - Set the Draw Style of SG2 to Bar, set all other subgraph Draw Styles to Ignore. - On the spreadsheet: Put this in cell K3: =IF(ID1.SG1@3>0,ID1.SG1@3-ID1.SG1@4,0) Put this in cell L3: =IF(ID1.SG4@4<>0,K3,K3+L4) where ID1 is the Zigzag study; edit as needed. Date Time Of Last Edit: 2017-01-06 15:03:02
ZZ leg +- histogram.PNG / V - Attached On 2017-01-06 15:02:58 UTC - Size: 55.43 KB - 794 views |
[2017-01-06 14:16:49] |
Thanks for that Tom. i was using excel to manually produce the histogram, but was curious to know if i could get it to appear at the bottom of my charts as a histogram.
[2017-01-06 14:26:32] |
Sorry, i wasn't very clear on that. I'm trying to produce a vertical histogram to show me graphically what my greatest rotation number is. I'm trying to produce a "profile" of rotations.
[2017-01-06 14:54:52] |
To force the histogram to only be above zero, use this in L3 instead: =IF(ID1.SG4@4<>0,ABS(K3),ABS(K3)+L4) Date Time Of Last Edit: 2017-01-06 15:02:40
ZZ leg + histogram.PNG / V - Attached On 2017-01-06 15:02:28 UTC - Size: 56.72 KB - 853 views |
[2017-01-06 14:57:36] |
Yes, but would that produce a vertical histogram?
[2017-01-06 15:04:56] |
What is a vertical histogram? Look at the pics in post #2 and post #5. Is the pic in post #5 a vertical histogram? |
[2017-01-06 15:28:10] |
No, they are not. A vertical histogram would be a "volume profile" (VbP), or a TPO profile.
[2017-01-06 15:50:07] |
What you want to do would require a custom program using ACSIL. http://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php |
[2017-01-06 17:00:39] |
Thanks for the input, i appreciate it.
[2017-01-07 09:41:52] |
User560062 - Posts: 100 |
I happened to ask a similar question on a different thread. When looking at indicators, first thing I would look at is what are the outlier values and the volume histogram tells you that easily. Is this something difficult for sierra to implement on all studies? Other packages have this feature out of the box.
[2017-01-07 17:02:21] |
i agree. it would be a nice improvement.
