Date/Time: Sat, 11 Jan 2025 19:48:07 +0000
cl data for april, may
View Count: 643
[2017-01-05 23:13:03] |
joer - Posts: 41 |
I am trying to load a continuous contract for cl 2016. I am using SC Historical Data and when I load the chart with a date range from 01/01/2016 to 12/31/2016 it is missing the data from 4/17 thru 5/16. I have the settings set for continuous charts and volume based rollover. What can I do to get the missing data?
[2017-01-06 05:00:49] |
You just need to re-download the missing data: https://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html#ReDownloading Missing data is not necessarily unusual to happen for various reasons. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
