Date/Time: Sat, 11 Jan 2025 20:00:13 +0000
List of ACSIL COLORS ....
View Count: 1249
[2017-01-05 19:51:11] |
User316362 - Posts: 210 |
Is there a list of all of the available ACSIL definable colors and RGB equivalent somewhere. e.g. COLOR_DARKGREY = RGB(?,?,?) and etc for each definable color by name? |
[2017-01-05 19:57:08] |
This is something you can search for on the Internet. All RGB color combinations are supported.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-05 19:57:32
[2017-01-05 23:32:02] |
DabbaDo - Posts: 148 |
Also there is a list of C++ definitions in the file C:\SierraChart\ACS_Source\sccolors.h
[2017-01-05 23:43:10] |
Yes but that is not a complete list.
