Date/Time: Sat, 11 Jan 2025 22:46:18 +0000
Will you finally look at quantity for lmax service ?.
View Count: 929
[2017-01-05 17:29:17] |
sierra28 - Posts: 120 |
hello Support. Ask me if you plan to set quantity for cfd contract from lmax at 1 and not 10. thanks |
[2017-01-06 02:21:30] |
OK, the problem with this kind of change is it requires a lot of planning and notification to users. We just have not had time to concentrate on it.
[2017-01-06 08:00:33] |
i'm waiting this correction to come back with you. Some others plateforms manage quantity for cfd "normally", for the rest Sierra is definitively better. |
Attachment Deleted. |
[2017-01-13 04:18:38] |
We are making progress towards working on this: CFD Order Quantity Proposed Change: LMAX: Proposed Change for CFD Order Quantities Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-13 09:03:25] |
Thanks to take in consideration this disagrement. I can't tell you if using a parameter is the best solution. If i have to set before a parameter for symbol i trade , it is not a problem for me. Do what is easier for you but i'd like that in the trade dom: 1- Quantity displays is the real quantity not a ten multiplier: 2- P&l is also real P&l not a ten multiplier. Objective of this improvment is to get trade dom easier and not confused to look at. rq: If i buy a germany 30 (2.5 quantity of a germany30 mini contract) what quantity will be display: 1 or 2.5 ? If i buy 1 cfd eur/usd what quantity will be display: 1 or 10 000 ? Date Time Of Last Edit: 2017-01-13 09:41:20
[2017-01-13 09:17:21] |
Through LMAX in the case of Germany 30, can you trade a fraction of a quantity? Does LMAX have CFDs for Forex pairs? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-13 09:27:30] |
lmax system refuse a fractional quantity for Germany30 but accept a fractional quantity for forex pairs: buy 1.5 germany30==> refused buy 1.5 euro/usd==> accepted Yes lmax have cfd for forex pairs |
fractional quantity.PNG / V - Attached On 2017-01-13 09:27:02 UTC - Size: 56.85 KB - 259 views |
[2017-01-13 10:06:49] |
i have note that for ex if i want to exit a position of 1 cfd indice contract, if the exit order is not completely served you can have 0.8 contract in rest. stange ... Date Time Of Last Edit: 2017-01-13 10:08:04
[2017-01-13 18:03:45] |
Based upon what you say in post #8, we should not make a change to how the quantity is specified for a CFD. Which is currently 10 times the actual quantity.
