Date/Time: Sat, 11 Jan 2025 20:07:38 +0000
don't get intraday volume on stocks
View Count: 847
[2017-01-05 17:07:05] |
User797603 - Posts: 29 |
I don't get my volume updated real time on my stock charts, when i open everything up each day the volume is accurate from yesterday, but as the day goes on and i am trading the chart prices and indicators update but not the volume https://froelibt.tinytake.com/sf/MTI0MzU3NV80NzA5MzM3 |
[2017-01-05 19:08:28] |
We see you are using Interactive Brokers. Refer to: http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#HistoricalRealTimeEquitiesDataVolumeDifferences Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-11 13:16:47] |
after following those instructions. how do i get the volume multiplier to stay at 100 in the sierra chart settings, i set it to 100 save it, and even if i pull back up the same stock i have to set it again. is there any whay to SAVE the 100 volume/open interest multiplier?
[2017-01-11 18:27:05] |
It will remain as long as you save the Chartbook: Here is a link to the Chartbooks page: http://www.sierrachart.com/index.php?page=doc/Chartbooks.html If you are changing the symbol of the chart, then it is necessary to specify this multiplier in the Global Symbol Settings for the symbol pattern: http://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
