Date/Time: Sat, 11 Jan 2025 20:59:06 +0000
Live data
View Count: 697
[2017-01-05 15:55:53] |
ShortVol - Posts: 7 |
Im viewing the /es and /qm on SC using a numbers bar analysis and for instance /es is 2264 and isn't updating. Do I need to purchase something further?
[2017-01-05 16:44:48] |
Refer to: Is Historical and Real-time Futures Data Included? Also those are not valid symbols. The correct symbols are in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-05 17:57:39] |
im sorry. you are correct. I am looking at ESH17
Untitled-1.jpg / V - Attached On 2017-01-05 17:57:31 UTC - Size: 527.48 KB - 242 views |
[2017-01-05 18:02:13] |
OK this is good. Once again, refer to: Is Historical and Real-time Futures Data Included? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-05 18:04:33] |
Yes. I have paid the 35 for this.
[2017-01-05 18:06:23] |
sorry again. im following the instructions.
[2017-01-05 18:18:24] |
Before proceeding, tell us who your futures broker is.
[2017-01-05 18:50:30] |
TD is my futures broker. I have active the SC charts data feed. but im lost from here
[2017-01-05 18:57:09] |
We activated the CME Group Exchange on your account. Follow through the instructions here to connect Sierra Chart to your TD Ameritrade account: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices Make sure your TD Ameritrade account has at least 500 USD in it.. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-05 19:17:42] |
OK I think im up and running. Thank you much!
