Date/Time: Sat, 11 Jan 2025 20:50:34 +0000
Sierra - TT chart
View Count: 826
[2017-01-05 15:30:41]
buylosellhi - Posts: 60
I'm using TT FIX connection to use with Sierra. The connection is working for trading etc but when I load the chart I can see Sierra has backfilled the data (with a 10min lag ?) but there is a gap of a few mins before live data from TT is filled in.
In the attached chart which I loaded at 10:23am, chart looks like its populated correctly until 10:13am but then the next bar is 10:16am. Is there a way to fix this ?
Thanks much for your help.
imageSierra-TT chart.PNG / V - Attached On 2017-01-05 15:30:25 UTC - Size: 26.85 KB - 233 views
[2017-01-05 16:07:13]
My live data feed is IQ Feed.
[2017-01-05 18:59:04]
The historical data is going to be delayed by 10 minutes when using TT FIX.
The most reliable solution to the problem is to use the Sierra Chart Exchange Data Feed for data:
http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php
