Date/Time: Sat, 11 Jan 2025 19:49:22 +0000
hello
View Count: 654
[2017-01-05 13:58:59]
User210780 - Posts: 7
I have download your sierra chart ,but I can not use it .can you help me?
[2017-01-05 13:59:59]
can you help me
[2017-01-05 14:23:01]
Yes we can help.
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on.
If you require real-time futures data, then refer to:
https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php
[2017-01-05 14:25:20]
the cmegroup data,and I only want to see the chart,So I need a chart software.can you help me ?
[2017-01-06 02:23:39]
Did you require real-time data or just historical data for CME group?
[2017-01-06 02:34:32]
I want to know why your datas have Several points of price difference with CMEGROUP data.can you explain ,what is the reason?
[2017-01-06 03:18:36]
Explain the differences you are referring to.
https://www.sierrachart.com/index.php?l=doc/PostingInformation.php#Image
