Date/Time: Sat, 11 Jan 2025 20:47:59 +0000
Intraday Data File Management - Compression
View Count: 740
[2017-01-05 08:22:32]
CarlRostron - Posts: 80
I noticed that my Intraday Files never seem to get compressed. See image.
Should this be done automatically or is there a setting that I need to schedule the compression for? If not, is there a reason I can check as to why it isn't compressing?
image2017-01-05_08-18-00.jpg / V - Attached On 2017-01-05 08:21:54 UTC - Size: 139.24 KB - 287 views
[2017-01-05 15:17:01]
The compression does not automatically run. It must be manually started and done a time where you can leave Sierra Chart running with no needed interaction for an extended time.
