Date/Time: Sat, 11 Jan 2025 20:46:55 +0000
Shapes (Squares, Circles etc) are hidden by (Ichimoku) Senkou Span A&B Cloud
View Count: 1109
[2017-01-05 06:40:42] |
User186889 - Posts: 53 |
Hello Sierra I am using Ichimoku signals on my charts. Which work well thankyou, however, when I add a shape (such as a triangle, circle or square) then if there is a 'Cloud' filled (i.e. the Senkou Span AB Cloud) then the cloud hides the shapes BELOW the Cloud - even though straight lines work OK are are shown ABOVE the Cloud. I have checked that on SenkouSpanAB 'Studies' the following box is ticked [Draw Study Underneath Main Price Graph] and so are SenkoSpanA and SenkouSpanB ticked as well but I still can't see or get at the shapes - Instead I have to 'Hide' SenkouSpanAB to get at the shapes (which defeats the object of having the cloud) Can you help please - Regards, Mark (UK) |
[2017-01-05 15:23:50] |
How are the shapes being drawn? Are they from a study or from the Marker drawing tool? If they are from a study, refer to: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
