Date/Time: Sat, 11 Jan 2025 20:46:46 +0000
Problems with Eurodollar symbol
View Count: 1220
[2017-01-05 04:23:54] |
Kwill721 - Posts: 24 |
When placing an order in Eurodollar futures, I'm getting the error message: "CQG order update (Rejected). Text: Symbol is incorrect or not defined. Internal Order ID: 7150. Service Order ID: (none). Symbol: F.US.GE5H17 | 2017-01-04 23:00:06 *" The symbol used is what's listed in the "Find symbol" menu for the March '17 Eurodollar. Also, the charts aren't updating in real time. I've experienced no problems with other market symbols, just the Eurodollar. I have the CQG feed with Amp Futures (CQG Fix Trading). |
[2017-01-05 05:31:25] |
Follow the instructions here to perform a Full Reset of the Symbol Settings: https://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#FullResetSymbolSettingsSteps The correct symbol is: F.US.EDAH17 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
