Date/Time: Sat, 11 Jan 2025 20:04:06 +0000
Would Like 'Cut' Chart Calculator Line
View Count: 850
[2017-01-04 23:22:13] |
ged - Posts: 233 |
Chart Calculator lines seem not to be susceptible to the 'cut' or 'extend' functions. It is not always possible to adjust the length of a Chart Calculator line, either shorter or longer, and maintain the exact same degree. Is there a way chart calculator lines can be cut or extended, maintaining the exact same degree? If not, are these functions you would consider adding? |
[2017-01-06 02:22:26] |
We will look into this.
[2017-01-10 23:40:24] |
In the next release Cut functionality will be supported with the Chart Calculator lines but not extend. That cannot be supported.
