Date/Time: Sat, 11 Jan 2025 20:52:46 +0000
Ichimoku Cloud
View Count: 1206
[2017-01-04 18:17:40] |
User26753 - Posts: 43 |
Could you help to plot the Ichimou Cloud transparent?. I mean, with the same Senkou Span Lines, but with the kumo transparent. Thank you in advance |
[2017-01-04 18:42:14] |
For transparency, you need to use the Transparent Draw Style pairs for the Subgraphs drawing this cloud. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#DrawStyle http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#TopBottomStyles Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
