Date/Time: Sat, 11 Jan 2025 20:41:14 +0000
URGENT sierra crash
View Count: 684
[2017-01-04 16:43:34] |
User472677 - Posts: 356 |
Hello, I am seeing the strangest situation. As soon as sierra is started, computer crashes and shuts down. I have tested extensively, it does NOT HAPPEN WITH ANY OTHER PROGRAM. I have reinstalled sierra, same result. URGENT, please point me in the right direction. |
[2017-01-04 17:28:56] |
This is going to be a hardware problem on your side. Also, it does not help to mark this as Urgent. Possibly an issue with your storage drive, or RAM. Or possibly an operating system level problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
