Date/Time: Sat, 11 Jan 2025 20:44:35 +0000
Modify a study
View Count: 1202
[2017-01-04 16:23:56] |
User608062 - Posts: 5 |
Can you guide me how to. I like to modify a study and reflect on my chart. An Example would be add a midline in RSI.
[2017-01-04 18:31:57] |
Refer to: http://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html If you just want to add a line, then follow the instructions here: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#AddingHorizontalLine Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
