Date/Time: Sat, 11 Jan 2025 20:46:42 +0000
CCI CROSS LEVEL & CUSTOM SOUNDS
View Count: 898
[2017-01-04 15:49:31] |
isa74 - Posts: 54 |
How it is possible to set-up 4 different sounds for 4 differents level of crossing on the CCI ? If I use this code within the indicator, how can I affect a specific sound for each level ? =OR(CROSSOVER(SG1,-100),CROSSOVER(SG1,-200),CROSSOVER(SG1,100),CROSSOVER(SG1,200)) Thanks ! |
[2017-01-04 18:08:40] |
The only way this can be done is by adding the Commodity Channel Index study four times to the chart Each one will need to be set to use a different Alert Number. And the formula needs to be broken up into 4 individual formulas, each one assigned to one of the four instances. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-04 18:09:11
