Date/Time: Sat, 11 Jan 2025 20:50:23 +0000
Attached order not adjusting to slippage
View Count: 634
[2017-01-04 14:27:42] |
User771416 - Posts: 47 |
For some reason my attached orders are no longer adjusting to slippage. If, for instance, I place an order with a 5 tick target and i get filled 2 ticks from my intended entry (on a stop order), my target is being placed 3 ticks from my actual entry. I do have the check box checked to "Adjust Attached Orders to Maintain Same Offset of Parent Fill". |
[2017-01-04 17:57:42] |
This is because server-side bracket orders have been enabled. Refer to: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#AdjustAttachedOrders You need to disable those. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-04 18:02:02] |
Thanks for the info. I'm not sure how that became active without me going in and activating it, nonetheless, i've changed it.
