Date/Time: Sat, 11 Jan 2025 20:42:37 +0000
Balance for Simulated Trading
View Count: 845
[2017-01-04 09:11:56] |
CarlRostron - Posts: 80 |
I am doing some Simulated Trading within Sierra Charts and have had a look around where you set the initial Balance but cannot locate this. Is this supported within SC please? Thanks |
[2017-01-04 09:23:37] |
This is not supported. We expect it will be sometime this year. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
