Date/Time: Sat, 11 Jan 2025 19:54:03 +0000
How can I draw a line at 2 months high low?
View Count: 746
[2017-01-04 08:06:03] |
vrunrun - Posts: 53 |
I tried to plot a line showing high & low of 2 months ago (i.e. November) in a monthly chart but failed. I used the study "Period OHLC - Variable Period" with "Time Period Type" set to Months and "Time Period Length" set to 2. I can view and verify the high in the monthly chart. However, the low appeared to be the low one month ago (i.e. December low). Pls check and advise. Thx.
[2017-01-04 08:31:07] |
Provide an image of the chart, by following these instructions: https://www.sierrachart.com/index.php?l=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-04 08:40:54] |
http://www.sierrachart.com/image.php?Image=1483519083902.png
[2017-01-05 19:14:08] |
We have looked at the chart and it looks correct to us. However, the low appeared to be the low one month ago (i.e. December low). Why is this a problem? This is what it should be. Between November and December, December has the lowest low.
[2017-01-05 19:54:07] |
This is what we see: http://www.sierrachart.com/image.php?Image=1483646011711.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-06 03:56:03] |
I thought the study will display the high and low for EACH bar in the monthly chart. Maybe this study cannot do what I want. What I want is I would like to automatically draw a line at Nov high and Nov low so that I can overlay the Nov high and Nov low from monthly chart to intraday chart. The 2nd part i.e. overlay should be easy but this 1st part i.e. get the high and low in Nov and display in intraday chart is the problem for me. Pls advise how can I achieve this. Thx. |
[2017-01-06 04:37:31] |
If you want the high and low for each bar in the chart, then simply set the Time Period Length Input with the study to 1.
