Date/Time: Sat, 18 Jan 2025 13:12:39 +0000
Bloomberg used as data feed to SC
View Count: 1798
[2017-01-04 04:51:26]
User857142 - Posts: 82
Hi
If I have a bloomberg access, can it be used to feed data in Sierra Chart? This is wrt to Indian Exchange.
Also, when can we expect you offering NSE (National Stock Exchange) data under your data services?
Date Time Of Last Edit: 2017-01-04 04:51:59
[2017-01-04 05:10:37]
No, Bloomberg is not supported.
Not sure at this time.
[2018-02-19 08:09:12]
Hi
Wrt my last query, I saw Bloomberg FIX under DTS service. Is it now supported? If yes, how to connect my Bloomberg data to Sierra Charts?
Thanks!
[2018-02-19 10:41:56]
Bloomberg FIX integration is being worked on for one particular customer and is trading only. No market data.
This is temporarily on hold.
[2018-02-19 11:10:12]
But without data being relayed to Sierra Chart from Bloomberg, how is that customer doing trading? Can you arrange the same setup for me?
I have bloomberg. Since, its charting facility is pathetic compared to Sierra Chart, i want to use it as a market data provider.
Can you do something about it?
Temporarily on hold means (NSE market data)? Have you stopped solving this by having a tie up with some Indian broker or everything is almost done and waiting for some last moment approval?
Date Time Of Last Edit: 2018-02-20 08:30:32
[2018-02-20 08:30:01]
Hi there...Waiting for the reply!
[2018-02-20 17:51:44]
This customer will be using the Sierra Chart Exchange Data Feed for data:
There are a couple of reasons including the fact that we have other higher priorities that come up that are easier to achieve and support than this. Also the particular group in India that we are working on this with, has to finish something with their risk management module.
Date Time Of Last Edit: 2018-02-20 17:52:23
