Date/Time: Sat, 11 Jan 2025 17:55:59 +0000
Limit renko bars
View Count: 627
[2017-01-03 21:07:55] |
User955877 - Posts: 2 |
Hi, How to limit the number of renko bars visible on chart (for example to no more than 1000 bars)? I am using number bars on renko chart and after couple of minutes with multiple windows open the software becomes very slow (I have set number of days to load to 1 in chart settings). Using "Reload and Recalculate" on all of renko chart windows helps for some time until charts fill with bars again. Kind regards, Radek |
[2017-01-03 22:08:03] |
There is no way to limit a chart to a number of bars. Only days. Refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often We would not expect the performance problem that you are describing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-03 22:08:34
