Date/Time: Sat, 11 Jan 2025 21:01:30 +0000
What Study to Use for Daily OHLC Single Point of antoher study (eg a MA)?
View Count: 1024
[2017-01-03 18:10:25] |
User360283 - Posts: 506 |
I would like to plot the point of the daily high and low of a study such as a MA. Using the Daily H/L Single Point does not seem to work. What is the alternative Thanks |
[2017-01-03 18:24:59] |
There is not one.
[2017-01-03 18:29:06] |
The closest available is this study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s371 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-04 11:55:11] |
The suggest study only displays Hi/Lo lines. I want the study to plot single for the targeted study such as a MA, plotting points similar to the DAILY OHLC Single Point study. Is there a way to do this? It would be very useful. Thanks |
[2017-01-04 17:31:48] |
This is not supported.
[2017-01-04 17:34:47] |
Please provide an estimate to develop at the 50% new feature rate thanks |
[2017-01-04 18:06:05] |
We are not willing to do that because we simply have no time to get to it now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-04 18:06:31
