Date/Time: Sat, 11 Jan 2025 19:54:44 +0000
Trade Activity Log - Text color no longer differentiated black/red in release 1504
View Count: 972
[2017-01-03 17:30:45]
User264623 - Posts: 28
On the 1504 release it seems the Trade Activity Log text coloring (black/red for positive/negative values) has disappeared? The values are all black in color, regardless of positive or negative.
Reinstalling version 1501 brought back the black/red coloring. Is there a new setting that I need to change in the 1504 version to enable red coloring of negative values?
[2017-01-03 18:55:48]
Thank you for pointing this out. This will be resolved in the next release.
[2017-01-03 20:49:02]
user8888 - Posts: 159
The colors of some elements of the Quoteboard has been altered aswell
[2017-01-03 22:06:41]
Specifically what?
[2017-01-03 22:43:05]
The "Quote Board: Label Row Background" was working fine.
Now ignores the color you specify and uses the same color of the whole Background for it.
The same happens with the "Label Row Foreground/Text"
[2017-01-03 23:46:29]
We will check on this.
[2017-01-05 05:38:55]
This is now resolved. Update to version 1505.
[2017-01-05 11:40:46]
Yes, the colors of the QB work again. Thanks!
but, regarding the TAL, the color of the negative values are not red but brilliant Green or something
How can we change that setting?
Thank you
Private File
[2017-01-05 13:53:51]
Global Setings >> Graphics Settings
Change color of Position Tab Short
[2017-01-05 14:09:15]
In the Trade Activity Log, this only applies to "Trades" tab. Text in the "Trade Statistics" and "Period Trade Stats" tabs are still colored black for both positive and negative values.
[2017-01-05 14:16:49]
We released a new revision which also solves these other field coloring issues. Update Sierra Chart again with Help >> Download Prerelease.
[2017-01-10 16:20:16]
infpz - Posts: 826
Is this still an issue? I received this from someone running 1505:
I updated my charts to the latest 1505 version & it changed the color of the font in the trade activity log, (profit/loss, running P/L columns where losses are bright green & wins are black). I know this is trivial but I find it really annoying! I can’t find where to changer this text color anywhere, can you tell me?
[2017-01-10 16:29:58]
There is now a way to set custom colors for these (See post #9 above).
When you update to the new version, the default is bright green currently. It should be a one time setting change.
[2017-01-10 16:32:36]
infpz - Posts: 826
Fantastic - thank you for the reply!
[2017-01-10 17:42:26]
We will make sure the colors are properly set in the next version.
