Date/Time: Mon, 16 Sep 2024 19:15:58 +0000
Setting up an alert with several coding and conditions
View Count: 795
[2017-01-03 17:29:44] |
isa74 - Posts: 54 |
Sir, I would like to know if it is possible to have one single alert that would trigger only if all the conditions are fully filled, conditions that would be specific in several indicators ? For example, if I want these 2 conditions to be respected to launch a specific sound alert file: MACD curve cross signal curve: CROSSOVER(ID13.SG1.ID13.SG2) CCI curve cross level +100 : =OR(CROSSOVER(SG1,-100),CROSSOVER(SG1,-200),CROSSOVER(SG1,100),CROSSOVER(SG1,200)) Each coding line will be implemented on each indicator, right ? How do I link them together ? Thanks ! |
[2017-01-03 18:38:05] |
You will need to use the AND function. Here is the relevant documentation for this: http://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php#ORANDFunctions The formula will need to go either on the CCI or MACD. Formulas can reference other studies. Refer to: http://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php#ReferencingOtherStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-22 13:43:37] |
Juno Best Day Ever - Posts: 3 |
Hello, I would like to have a buy trigger (Trade System) based on more than one alert/condition. I have one set up for a single condition, can you please explain how to add alerts/conditions to the Trade Sysytem? I am a beginner. |
[2024-05-22 14:57:24] |
John - SC Support - Posts: 34453 |
As mentioned above, you need to use the AND() and/or OR() functions. Here is the link to the information for these: http://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php#ORANDFunctions Also, all the documentation for how to setup Alert formulas is at the following link: Study/Chart Alerts And Scanning For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
