Date/Time: Sat, 11 Jan 2025 17:44:00 +0000
Sounds Alerts & Files
View Count: 653
[2017-01-03 17:26:13] |
isa74 - Posts: 54 |
Sir, I would like to suggest an improvement relative to the visibility of the sounds named files which are not practically full readable once implemented into Sierracharts, when one choose specific names which are superior at 9 caracters. See attached. Thanks. |
sc_sierracharts_interface_global-settings_alerts-naming.png / V - Attached On 2017-01-03 17:25:56 UTC - Size: 28.48 KB - 217 views |
[2017-01-03 18:12:02] |
We will solve this in the next release.
