Date/Time: Sat, 11 Jan 2025 17:50:29 +0000
no chart functionality
View Count: 586
[2017-01-03 14:37:07] |
User259816 - Posts: 2 |
How do I activate a symbol to make it live. It is 8:34AM CST January 3, 2017 and none of the symbols that I enter have any live activity in them. How do I view ESH7? Or what do I need to do to make this symbol active in this demo account? Do I need to go to a paid version to make this service fundtion? Does this demo of SC allow me to see NYSE stock symbols? What do I need to do to view stock symbols? I am signed up with Infinity and I have their demo running simultaneously. It appears their data is flowing. |
[2017-01-03 17:51:45] |
For real-time futures data, refer to: http://www.sierrachart.com/index.php?page=doc/FuturesData.php US stock symbols are supported. You just need to manually enter those. Here are instructions: http://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.php#SetupInstructions The symbol for ES futures is: ESH17 If you want to use your TransAct/Infinity account, follow through the setup instructions here: http://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions Also, if you want to also get stock data it is necessary to use your own Sierra Chart account which you are currently using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-03 17:53:26
