Date/Time: Sun, 12 Jan 2025 18:47:40 +0000
[User Discussion] - Backtesting performance
View Count: 1379
[2017-01-03 12:43:05]
User514837 - Posts: 47
Good morning, I want to backtest strategies with the accurate backtesting method. I have intraday chart and data is 1 tick: http://www.sierrachart.com/index.php?page=doc/Backtesting.php#ImprovingPerformanceOverall
However it is so slow that after 2 hours of backtesting at 30720 speed, it has only looked at ~30days worth of data. Is this performance to be expected from this kind of backtesting or could there be something wrong? My PC specs are acceptable I believe (8gb ram, i5 processor).
[2017-01-03 17:58:52]
Make sure on the Replay window you have not set the Replay Mode to Calculate at Every Tick/Trade. Do not use this.
[2017-01-03 18:06:53]
I have the accurate trading system back test mode selected, not the "Calculate at Every Tick/Trade".
[2017-01-03 18:32:21]
OK, then this is apparently what the back test speed is. This is not necessarily unusual since there is a lot of processing involved.
See if updating to the latest version makes any improvement. But we would not expect much difference if any. A faster computer would also help.
Date Time Of Last Edit: 2017-01-03 18:33:54
[2017-01-19 19:07:52]
User460064 - Posts: 12
Hello Support, for improving backtesting speed, the best option is a i7 extreme, or a Xeon with a lot of cores?
Date Time Of Last Edit: 2017-01-20 02:25:01
[2017-03-12 09:18:33]
opci - Posts: 90
I have a problem with bactest ... click traders backtest both solution and before that I reduced the chart on two days ... and that backt. takes too long and freeze platform ... is this normal or something mistake? thank you
Date Time Of Last Edit: 2017-03-12 09:19:13
