Date/Time: Mon, 25 Nov 2024 14:34:41 +0000
Can I have two separate brackets orders depending on buy column?
View Count: 1425
[2013-08-05 22:09:44]
HeavyMike - Posts: 25
In my trading spreadsheet imagine I have column Y to TRUE(based one formula)and column Z to be TRUE(based on a different formula), I want it to buy when either is TRUE (which I can easily do), BUT how can I have different attached orders for each? So for Column Y I may want to set stop limits +1 and -1pt, while for a buy for column Z I want my stop limits to be +2 and -2pts. How can I do this?
[2013-08-05 22:58:34]
This is not supported right now, but we will make a note to allow the Spreadsheet System for Trading study to adjust the Stop and Target offsets. If the defined Attached Orders use multiple OCO groups, this is only going to adjust OCO group 1.
[2014-02-13 11:39:18]
User60591 - Posts: 39
basically the same question,
having the spreadsheet system with multiple signals on the same instrument. I want to be able to reference different OCO group (attached orders) for different signal .
i.e OCO1 Y= true, target 5 stop 5, OCO2 Z=true; target 8, stop 10 etc.
Is this possible now, or you need to do adjustments as stated in previous post?
Is there a way to do it without going trough Advanced Custom Study Interface?
thnx
Date Time Of Last Edit: 2014-02-13 11:39:59
[2014-02-13 18:33:47]
Adjusting more than 1 Attached Order Target or Stop from the Spreadsheet System for Trading study is not supported and will not be. You need to use ACSIL:
http://www.sierrachart.com/index.php?l=doc/doc_ACSILTrading.html
