Date/Time: Sat, 11 Jan 2025 17:52:30 +0000
All data interrupted after Dec30th
View Count: 788
[2017-01-02 11:12:34] |
User57584 - Posts: 30 |
Hello, I do not have any data after 2016-12-30. My account is renewed; date on my computer is ok. I do not understand what's happening. Could you please help me. Thank you in advance. JM Boulay |
[2017-01-02 18:09:43] |
The US markets are closed today. If the problem is with another symbol, tell us the exact symbol and tell us only one of the symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-03 09:06:34] |
Sorry, it was just because the markets were closed. My mistake. Thank you. |
