Date/Time: Sat, 11 Jan 2025 17:56:11 +0000
Trade activity log after backtesting shows only last 2 months of trading data
View Count: 583
[2017-01-02 08:13:42]
User261741 - Posts: 22
Hi!
Can you please help regarding the above question?
I think everything is set properly.
I am backtesting 3 years of historical intraday data (1hr bars) and every trade is correctly marked on the graph (entry and exit) for all three years.
After the backtest (bar by bar) is finished I can see only data from 08th of November 2016 (changing start time in trade activity log doesn't help).
Am I missing something?
Thanks!
[2017-01-02 17:32:59]
Scroll the chart back about two years, showing a place where there are order fill markers on the chart and then post an image of the chart by following these instructions:
Make sure you follow the specific instructions for posting an image of the chart.
[2017-01-03 08:46:22]
I figured it out... It seems that I didnt correctly applied date range change...
Sorry...
