Date/Time: Sat, 11 Jan 2025 17:34:42 +0000
Query
View Count: 663
[2017-01-01 10:33:55] |
hursthead - Posts: 28 |
Hi, I am planning to switch brokers but still use Sierra as my platform - data provider will be provided by a different party. As such, I am trying to keep the service balance minimal during the transition. Could you tell me when is the last day I need to make this transition? For SC platform I see last day as 19 Jan 2017, but I am not sure when is the last day for data+exchange fees? On the account it says ending date is 31 Jan 2017 for both data and exchange fee - could you confirm that is correct? If so, would you say my last day to make the transfer is 19 Jan 2017? Just want to make sure I am correct on this. Thank you and Happy New Year. |
[2017-01-01 11:07:06] |
On the account it says ending date is 31 Jan 2017 for both data and exchange fee - could you confirm that is correct? Yes this is correct.We set your account Current Usage Time Ending Date to 2017-01-31 to match. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
