Date/Time: Sat, 11 Jan 2025 20:44:26 +0000
outline candlestick
View Count: 2088
[2016-12-30 17:09:29] |
Kinobe - Posts: 86 |
Hi Is it possible to not have outline candelstick but keep wick like image. A feature could be add to Graph Draw type "Candlestick with no Outline". |
ex_candlestick.jpg / V - Attached On 2016-12-30 17:09:00 UTC - Size: 39.08 KB - 331 views |
[2016-12-30 18:19:31] |
You just need to set the Candlestick Outline and Fill colors to be the same. Refer to: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-04 01:10:40] |
I tried it already and it is not convenient because my trading is very visual. The wick is the same color of the body and when the space bar is small, it is pretty hard to differentiate the body and the wick- see attached picture. If the wick would remain black, it would be great. |
BodyWick_sameColor.jpg / V - Attached On 2017-01-04 01:09:30 UTC - Size: 143.34 KB - 310 views |
[2017-01-04 04:36:24] |
You need to uncheck this setting in Global Settings >> Graphics Settings: Graphics Settings: Color Candlestick High-Low Using the Outline Colors (Global Settings >> Graphics Settings >> Other) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
