Date/Time: Sat, 11 Jan 2025 17:55:01 +0000
Improvements for Study
View Count: 756
[2016-12-30 09:55:42] |
nicktrader - Posts: 725 |
The Study „Volume at Price...V2“ ist a wonderful tool. Many thanks but from my point of view there are some points I would improve. - In practice, this study is difficult to work with because the information content is very limited. I use the chart header and also Chart Value Window as an information source. Here in my example I prepared 7 triggers only. One Study for Ask Volume and one Study for Bid Volume. To switch off all other Triggers (8 – 56) for the Header and the Chart Values Windows is not manageable (try by yourself). At the moment I do not understand the logic to switch off correctly. - It would be very helpful to use the function “Number of Bars to Calculate” and “Automatic clear...” - Furthermore, it would be very helpful to extend the Draw Style by adding "Square Offset Right" and "Square Offset Right Body" esp. if you use the Study two or more times. Many thanks |
Volume at Price...V2 Study.png / V - Attached On 2016-12-30 09:50:58 UTC - Size: 76.91 KB - 271 views |
[2016-12-30 22:02:55] |
In the next release, this study will by default set all of the Subgraphs to not display in the Chart Values Windows.
