Date/Time: Sat, 11 Jan 2025 17:50:48 +0000
MURRAY MATH LINES LOOK BACK PERIOD
View Count: 1550
[2016-12-29 16:11:08] |
Trader&Hunter - Posts: 131 |
Can you give me an explanation on the Murray math lines what the look back period means? example If I have a look back period of 1.5. what does that mean? Thanks
Capture.PNG / V - Attached On 2016-12-29 16:11:00 UTC - Size: 2.54 KB - 320 views |
[2016-12-29 18:23:48] |
In the next release, this Input is being renamed to Square Width Multiplier. It is documented here: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s238 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-29 18:29:05] |
Ok but what does it mean exactly? what is it actually calculating?
[2016-12-29 18:53:49] |
We added documentation for the input named Square Width Multiplier here: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s238 Be sure to reload the page for the current content. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-29 18:54:17
