Date/Time: Sat, 11 Jan 2025 17:53:29 +0000
Statistical Analysis with spreadsheets and C++
View Count: 897
[2016-12-29 13:51:16]
User642139 - Posts: 20
I currently export all my spreadsheet data into Excel for further statistical analysis and research.
In light of the discontinued support of Excel functionality sometime in 2017 I am looking for alternatives.
Is trying write a program in C++ to do all the number crunching a practical alternative or am I completely off the mark there with what C++ is used for within Sierra?
Any advice or direction would be greatly appreciated.
[2016-12-29 17:46:09]
User787778 - Posts: 142
Have you considered copying and pasting your data from "Sierra Spreadsheet" into Excel and then doing the number crunching in Excel?
[2016-12-29 17:54:32]
@787778
Yes, I have. I will do this if needed, but I am looking to avoid this as it has led to errors in the past.
[2016-12-29 18:16:11]
There are no plans now to remove Excel support. This will not happen in 2017.
Yes this can be a practical alternative but we do not know exactly what you are doing.
